1. Thank you for visiting our community! Our free registration takes a matter of seconds. You'll enjoy a completely ad-free experience, have access to posting and our iPhone downloads. REGISTER TODAY!
  2. Avatar Theme Week continues with Tarantino Theme Week. We want you to update your avatar using any character from a Quentin Tarantino movie. When you do, be sure to post in the contest thread for a chance to win an iTunes Gift Card.
Un-tethered v. Tethered Jailbreak
Discussion in 'iPhone Jailbreak' started by KabaModern, Dec 11, 2009.
  1. KabaModern Zealot
    Mar 31, 2008
    Message Count:
    4,744
    Ratings Received:
    +17 / 0
    I'd venture a strong guess at Spring when the next iPhone will most likely be launched. We haven't got word on a 4.0 SDK for developers yet which indicates if they announce it soon hopefully it will be ready by the time the new iPhone is launched.
  2. tejas hadkar New Member
    Mar 1, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    3gs factory unlock
    hi kaba
    I am getting a factory unlocked 3gs which might be having the new bootloader 6.04 and can I jailbreak the factory unlocked I phone and if it gets rebooted it will it be able to boot it on its own without using pc as it is unlocked or I have to use blackrain........plz explain
  3. tejas hadkar New Member
    Mar 1, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    hi I am having 3g with 3rd 4th and 5th serial number 847,is it tethered or un-tethered jailbreak ....plz help :dft008:suprised
  4. KabaModern Zealot
    Mar 31, 2008
    Message Count:
    4,744
    Ratings Received:
    +17 / 0
    All 3G devices don't apply. Please read my first post more carefully. :)
  5. tejas hadkar New Member
    Mar 1, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    ok.......thank you for replying ......and what about 3gs
    I am getting a factory unlocked 3gs which might be having the new bootloader 6.04 and can I jailbreak the factory unlocked I phone and if it gets rebooted it will it be able to boot without using blackrain as it is unlocked or I have to use blackrain........plz explain
  6. daycheck Member
    Feb 27, 2008
    Message Count:
    165
    Ratings Received:
    +4 / 0
    What about factory referb phones... I just had to send my original 3gS into apple and they replaced it with a referb.... is there a way to look at the s/n or do I have to use the method mentioned in the first post....?
    thanks
  7. KabaModern Zealot
    Mar 31, 2008
    Message Count:
    4,744
    Ratings Received:
    +17 / 0
    You should most likely receive a slip or sticker with the serial number of the new iPhone with it. If not, you can use the DFU-mode method, or just simply activate it and try running blackra1n right away and see the results.
  8. daycheck Member
    Feb 27, 2008
    Message Count:
    165
    Ratings Received:
    +4 / 0
    It came with 3.1.3 on it.. :( and the s/n starts with a 5k0070z.....
  9. knightxxl New Member
    Mar 19, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    I have just purchased a 16g 3gs Jailbroken on 3.1.2 off of ebay for my wife, I have since found out from the seller that the phone is tethered and needs to be reset to blackra1n on powerdown..
    I have a 32g 3gs already jailbroken on Blackra1n, my worry is that on reset of the 16g that blackra1n will not reconise the 16g, only my 32g??? and then have to connect to itunes???
    Is the 16g synced to his blackra1n??
    Seller has offered me money back,
    Any help much apprieciated
  10. Aepyx New Member
    Mar 21, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    I'm trying to find out whether my 3G is gonna need a tethered or un-tethered jailbreak but when I try and find the bootrom version it doesn't show up in device manager. It has all the other string but misses out [iBoot: whatever]
    I've tried finding it in DFU mode and in recovery mode, but they both miss it out, so I'm out of ideas.
    I used f0recast and it said "maybe tethered; depends if refurbished" and the 3rd, 4th and 5th numbers of my serial are 010 :s
    Can anyone help?
  11. KabaModern Zealot
    Mar 31, 2008
    Message Count:
    4,744
    Ratings Received:
    +17 / 0
    No way. By the name conventions that would mean your iPhone was made this year, week 10. If your device is running firmware 3.1.3, you're out of luck anyway.
  12. meshe New Member
    Apr 1, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    3.1.3 with serial 922
    Iphone with 3rd, 4th & 5th digit in serial number below 939 (889224Q43NP).
    Currently running version 3.1.3.
    Can it be jailbroken (untethered)?
  13. iNinja Zealot
    Aug 8, 2008
    Message Count:
    4,274
    Ratings Received:
    +17 / 0
    The serial number is a good indicator - but the easiest way to check is to try it. Back it up, close iTunes, run Sn0wbreeze, try and reboot. If it works, your untethered. If not, just restore from your backup. Im presuming you have an iPhone 3gs BTW
  14. NewGuy Member
    Dec 30, 2009
    Message Count:
    456
    Ratings Received:
    +7 / 0
    Hes running 3.1.3
  15. iNinja Zealot
    Aug 8, 2008
    Message Count:
    4,274
    Ratings Received:
    +17 / 0
    I know - I meant Sn0wbreeze, not blackra1n - I edited my original post.
  16. morth58 Member
    Mar 17, 2008
    Message Count:
    185
    Ratings Received:
    +0 / 0
    thank you dev team for my new untethered jailbrake. donation submitted. It is a huge relief to know my phone will not be rendered useless my a mysterious reboot. Thanks again.
  17. Andrios New Member
    Jun 27, 2009
    Message Count:
    22
    Ratings Received:
    +0 / 0
    yup spirit worked for me!
  18. meshe New Member
    Apr 1, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    Is the jailbreak for 3.1.3?
  19. Europa Moderator
    Message Count:
    20,407
    Ratings Received:
    +2,661 / 2
    Yes, it's for 3.1.3.
  20. Roby718 New Member
    Aug 13, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    Wow, the first touch i had had a tethered serial. Then i had to get it replaced, and i got one with what looks like a untethered serial.
Share This Page
