1. Thank you for visiting our community! Our free registration takes a matter of seconds. You'll enjoy a completely ad-free experience, have access to posting and our iPhone downloads. REGISTER TODAY!
  2. Avatar Theme Week starts today and we're kicking it off with Star Trek. We want you to get your Trek on. Read more and learn how to update your photo here at eiC/iPopuli. Taking part means you could be randomly selected to win an awesome app, so join the fun.
New Printer - How to attach?
Discussion in 'Mac OS X' started by confusedxx, May 26, 2010.
  1. confusedxx Member
    Nov 19, 2009
    Message Count:
    50
    Ratings Received:
    +0 / 0
    I just bought a canon ip4700 printer. I am new to Macs and so I am wondering what is the best way to attach the printer?
    Should I attach it directly to the iMac and use a usb port or should I attach it to my NAS and then have access to a network printer from my Mac?
    I have a CD rom with software for the printer, but does it make a difference in the usage of the Software if the printer is attached directly or via a NAS?
  2. danipoak Member
    Dec 13, 2007
    Message Count:
    713
    Ratings Received:
    +0 / 0
    I'm not sure about connecting a printer to a NAS. I've always just plugged printers into my mac and it picks it right up, never needed to install any of the software that comes with it. I have an airport express and I did have it plugged into that at one time but since it is an Apple product again the software inside it just picked the printer right up and I was able to use it for a network printer.
  3. Cjvdh Zealot
    Mar 8, 2009
    Message Count:
    3,330
    Ratings Received:
    +7 / 1
    First of all are you trying to connect your printer via a cable or wirelessly through your internets wifi connection? If you are doing it with a cable then just plug the cable in the back of the computer and into the printer and it should configure it automatically also install the CD-ROM they provided you. If you are trying to connect it using WiFi just post back and I can help you out. I think your easiest and simply bet is going to be connecting it via an USB cable.
Share This Page
