iphone sync to OUTLOOK never ending
Discussion in 'Windows PC and iPhone' started by evinka, Apr 26, 2009.
  1. evinka New Member
    Apr 26, 2009
    Message Count:
    Ratings Received:
    +0 / 0
    I have 3000+ contacts in Outlook and I am trying to get them into new 16GB iphone and from there into new MACBOOK pro. It has been syncing via itunes for 90 mins already and doesn't show progress anywhere - surely that's not normal? can anyone help?
  2. sim New Member
    Aug 19, 2008
    Message Count:
    67
    Ratings Received:
    +0 / 0
    There is a chance there is a pop up window behind the iTunes window telling you that "X" percentage of contacts have changed and asking you to hit "ok".
    Steve
  3. evinka New Member
    Apr 26, 2009
    Message Count:
    Ratings Received:
    +0 / 0
    thanks Steve
    no pop up window sadly
    A friend just told me she also had difficulty with the first sync
    I am going to cancel it yet again and try just the calendar to see if sthg at least will sync
    Eve
  4. evinka New Member
    Apr 26, 2009
    Message Count:
    Ratings Received:
    +0 / 0
    http://support.apple.com/kb/TS1323
    A friend gave me this useful troubleshooting advice and I have disabled third-party add-ins and the calendar did sync HOORAY - now trying contacts...
  5. evinka New Member
    Apr 26, 2009
    Message Count:
    Ratings Received:
    +0 / 0
    IT WORKED! I disabled the 3rd party add-ins other than itunes...
    For Outlook 2007, follow these steps to disable third-party add-ins:
    1. Open Outlook 2007
    2. From the Tools menu, choose Trust Center.
    3. Select Add-ins from the left column.
    4. Look at the list of add-ins beneath "Active Application Add-Ins" and determine if anything is listed other than the "iTunes Outlook add-in." If so, continue on to disable those add-ins.
    5. In the Manage box, click COM Add-Ins, and then click Go.
    6. In the COM Add-Ins dialog, deselect the checkbox for each third-party add-in in this list.
    7. Click OK.
Share This Page
