1. Thank you for visiting our community! Our free registration takes a matter of seconds. You'll enjoy a completely ad-free experience, have access to posting and our iPhone downloads. REGISTER TODAY!
  2. Avatar Theme Week continues with Tarantino Theme Week. We want you to update your avatar using any character from a Quentin Tarantino movie. When you do, be sure to post in the contest thread for a chance to win an iTunes Gift Card.
Incoming call is not showing contct name
Discussion in 'iOS Software' started by leonardbd, May 31, 2010.
  1. leonardbd New Member
    May 31, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    When I'm receiving call it's not showing name from my contact, instead it's showing +880 1714086987 (as an example). It's putting a SPACE between country code and the cell number. I think that's the reason it's not matching the number with my contact. Is there any remedy to overcome this issue?
    My os 3.1.2 jailbroken,
    country Bangladesh.
    Need help, pls.
  2. chris5468 Member
    Jun 27, 2007
    Message Count:
    80
    Ratings Received:
    +0 / 0
    I've never heard of that happening. Try goggling the problem my friend
  3. psylichon Moderator
    Oct 31, 2007
    Message Count:
    17,596
    Ratings Received:
    +911 / 1
    Has it ever worked properly? It may just be an incompatibility with the way your provider shows incoming calls.
  4. leonardbd New Member
    May 31, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    Thanks dudes. I've solved the problem. I installed an add-on named Caller ID and format fix. That's it!! Leo
  5. kycophpd Member
    Jun 30, 2007
    Message Count:
    256
    Ratings Received:
    +0 / 0
    Hmm, post count makes me suspicious that this may be the person who added Called ID and format fix to Cydia.... I hope I am wrong.
  6. leonardbd New Member
    May 31, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    No dude. U r absolutly wrong. Thanks to him whoever made tha patch. I was desperately looking for a solution on everywhere.
  7. Tariq.sdk Member
    Jul 17, 2010
    Message Count:
    78
    Ratings Received:
    +0 / 0
    he is right, i had the same prob and got it fixed by the patch. thnx to the developer and leonardbd
  8. xgj New Member
    Sep 9, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    I registered here only to say that i have also the same problem just more complicated though :dft011:wicked_smile
    So i just bought an iphone 4 and when contacts are saved with the country code then it will display only their number when i receive a call but it is fine when i receive an sms from them. And the other way around, if contacts are saved without the country code, their name appears when i receive a call but not when i receive an sms.
    It is really frustrating! Anyone has any idea?
    Iphone 4, ios 4.1
  9. Watcher Zealot
    Mar 29, 2009
    Message Count:
    1,891
    Ratings Received:
    +44 / 0
    You all who're having this problem, you may want to list where you're from and what network you're on so we can better ascertain the issue and give you some tips on how to resolve it. I only mention this because I haven't heard about this happening on AT&T iPhones in the states, yet. Or at least not that I can remember.
  10. xgj New Member
    Sep 9, 2010
    Message Count:
    Ratings Received:
    +0 / 0
    you are right! I'm writing from Albania and using a factory unlocked phone that i bought in Switzerland
Share This Page
