1. Thank you for visiting our community! Our free registration takes a matter of seconds. You'll enjoy a completely ad-free experience, have access to posting and our iPhone downloads. REGISTER TODAY!
  2. Avatar Theme Week starts today and we're kicking it off with Star Trek. We want you to get your Trek on. Read more and learn how to update your photo here at eiC/iPopuli. Taking part means you could be randomly selected to win an awesome app, so join the fun.
File locations
Discussion in 'iOS Software' started by tom112089, Nov 6, 2010.
  1. tom112089 Member
    Jul 30, 2010
    Message Count:
    55
    Ratings Received:
    +0 / 0
    I'm sorry if this is in the wrong area but I didn't know where to post it. My question is where is the original location in ifile of the signal bars and other status bar .pngs on ios4 I looked for the originals because I want to edit them not start from scratch.
    And also how come no matter how many times I change the names and respring my 3G pngs are always opposite. Meaning the black one is where the silver should be and vice versa. Then I switch the names with ifile and respring and they still are backwards.
  2. gary_hendricks New Member
    Sep 18, 2010
    Message Count:
    79
    Ratings Received:
    +0 / 0
    You can try getting an app that allows you to "browse" the folders on your device. There are some lying around in the App Store.
  3. iphonewarrior Moderator
    Message Count:
    15,574
    Ratings Received:
    +851 / 5
    Hopefully this link will help you with changing the default carrier logo.
    Secondly, what name are you calling the 3G.png's? They have to be correct of they simply won't work. Another option to consider is that you may have something installed which is conflicting with the new setup.
  4. tom112089 Member
    Jul 30, 2010
    Message Count:
    55
    Ratings Received:
    +0 / 0
    in
    bundles/com.apple.springboard
    Of my custom theme. When I upgraded to iOS 4 alot of my theme didnt work anymore. I updated some of the file names and some now work but others don't for instance all of my black status bar pngs except the signal bars work but none of my silver ones work except the 3G logo which is the wrong one. And when I have cydia open none of the silvers work their all the originals. My new carrier logo is the only thing that stayed consistent from the time I added it like a year through everything till now.
  5. Operist Member
    Feb 17, 2011
    Message Count:
    127
    Ratings Received:
    +0 / 0
    They have changed in ios4 it's now called black and default respectively. None of the status bar stuff seems to work at all in cydia. It's non-skinnable I'm sure saurik is working on that. Hope this helps
Share This Page
