Attempted jailbreak ! Help
Discussion in 'iPhone Jailbreak' started by Philious, Jun 30, 2012.
  1. Philious New Member
    Jun 30, 2012
    Message Count:
    Ratings Received:
    +0 / 0
    Hi
    Attempted to jailbreak my iphone3g 4.2.1 without success and now the phone won't boot up or when connected to my pc with iTunes nothing?
    Can someone please help
  2. Mariouk Member
    Sep 8, 2010
    Message Count:
    283
    Ratings Received:
    +7 / 0
    Plug phone into iTunes keep both fingers on home and power button until iPhone is detected, restore, then rejailbreak
  3. Philious New Member
    Jun 30, 2012
    Message Count:
    Ratings Received:
    +0 / 0
    Thanks mate, I've tried redsnow and green poison to jailbreak but hasn't worked, it sounds simple enough but the phone just keeps saying try again
  4. RoofMonkey Genius
    Jun 21, 2010
    Message Count:
    8,962
    Ratings Received:
    +1,644 / 6
    Make sure you run the jailbreak program in administrator mode.
  5. blastewitz Member
    Feb 3, 2011
    Message Count:
    51
    Ratings Received:
    +0 / 0
    It happened to me too . U need a iMac to kick it out of recovery mode for some reason that's the only thing that worked for me with my iPhone 3G after u kick it out on a mac u shud b able to do the jailbreak. I didn't risk doing it.on pc but rather I've done it on a iMac .I hope this helps :)
  6. Mariouk Member
    Sep 8, 2010
    Message Count:
    283
    Ratings Received:
    +7 / 0
    U dont need an iMac, just restore to factory in I tunes then rejailbreak, it will wipe everything but I'm sure it will work.
  7. MoneyMaker79 Zealot
    Dec 15, 2008
    Message Count:
    2,148
    Ratings Received:
    +157 / 0
    Make sure you backup your iPhone in iTunes before choosing to restore. Then run your backup to put everything back on the iPhone and then Jailbreak. Administrator mode does need to be used if on a Windows computer.
  8. blastewitz Member
    Feb 3, 2011
    Message Count:
    51
    Ratings Received:
    +0 / 0
    Believe me I've tried restoring but iTunes didn't even recognise my iPhone 3G that's why I had to do it on iMac
  9. Mariouk Member
    Sep 8, 2010
    Message Count:
    283
    Ratings Received:
    +7 / 0
    Try this.. Plug iPhone into iTunes, hold home and power button until it is recognised, let go of power button but keep hold of home ...
  10. iphonewarrior Moderator
    Message Count:
    15,591
    Ratings Received:
    +860 / 5
    Thread moved to the iPhone Jailbreak section.
  11. Philious New Member
    Jun 30, 2012
    Message Count:
    Ratings Received:
    +0 / 0
    Thanks mariouk your suggestion worked, now I right clicked on redsnow and fr,om the drop downtown menu selected "run as administrator " but still didn't work am I doing this right or wrong???
  12. iphonewarrior Moderator
    Message Count:
    15,591
    Ratings Received:
    +860 / 5
    Do you have the iPad baseband installed?
    A new feature released by the Dev-Team allows the user to downgrade the iPad baseband. What iTunes errors are you receiving?
  13. FlwrPwer Evangelist
    Aug 7, 2008
    Message Count:
    2,688
    Ratings Received:
    +128 / 0
    He's trying to jailbreak an iPhone 3g....not an iPad. Don't worry. I got your back. ;)
  14. iphonewarrior Moderator
    Message Count:
    15,591
    Ratings Received:
    +860 / 5
  15. iphonewarrior Moderator
    Message Count:
    15,591
    Ratings Received:
    +860 / 5
    Also, having the iPad baseband installed can cause problems when jailbreaking, updating and restoring.
  16. Europa Moderator
    Message Count:
    20,691
    Ratings Received:
    +2,842 / 2
    Restore to factory settings in iTunes. Use DFU mode if iTunes doesn't recognize it. This will do a clean install of 4.2.1 on your iPhone 3G. Then jailbreak using greenp0ison RC5. You can apply your backup after you successfully jailbreak it. This is done by right clicking on your iPhone in iTunes and selecting restore backup. This only restores your backup, not the firmware.
    How to apply your backup after you jailbreak:
    [IMG]
    [IMG]
    • Informative Informative x 1
  17. peterthomas Member
    Oct 4, 2011
    Message Count:
    Ratings Received:
    +0 / 0
    I hope your problem would be solved till now, but to be true, what actually attracted me was the title of your post which seems to be a call for the help for a real Jail-Break!
Share This Page
