What can I do with a couple of iMac G3s with OS 9.0 and 9.2?
This is a discussion on What can I do with a couple of iMac G3s with OS 9.0 and 9.2? within the iMac forums, part of the Apple Hardware and Software category; Originally Posted by fury I have one working Revision A iMac, running 9.something Well, after all this talk, if it's ...
+ Reply to Thread
Page 3 of 3
FirstFirst 1 2 3
Results 21 to 30 of 30
Thread: What can I do with a couple of iMac G3s with OS 9.0 and 9.2?
  1. #21
    geordisjd's Avatar
    Join Date
    Jul 2007
    Posts
    2,725
    42
    Quote Originally Posted by fury View Post
    Well, after all this talk, if it's working, what do you really want out of if? (I gather you probably don't have a OS 9 install CD?
    Too Many Macs To Count
    4 or 5 iPods
    1 iPhone (iPhone 3G by now)
    taH pagh taHbe' net SaHtaH !
  2. Click here to register for our iPhone forums and remove these ads.
  3. #22
    Eragon's Avatar
    Join Date
    Jan 2008
    Location
    Frederick, MD
    Posts
    2,973
    76
    I bought my iMac last July. The first Apple I've owned since the days of my Apple II+. One of the things I was hoping to do with the iMac was use it to play children's software. Unfortunately, a lot of the software was made for Mac Classic and not for the Intel processors. Some of the programs I was able to run via Parallels. Some, I wasn't.
    Bottom line: there still is a market for older macs, especially ones with PPC processors.
    Larry and Harry Spotter -
    Follow me on Twitter, Neutrino @ Everything Android
  4. #23
    geordisjd's Avatar
    Join Date
    Jul 2007
    Posts
    2,725
    42
    Quote Originally Posted by Eragon View Post
    And u can still do that. For $100, u can get a DV iMac G3 on eBay. Make sure you get a 4-500mhz processor and at least 256 mb of ram. You can upgrade rather cheaply to up to 576 mb. My 1 gb was a fairly expensive custom upgrade. Make sure it was fitted with a bigger Hd. Mine has 80GB. It cost me $125 before my crazy memory upgrade. You just keep OS 9.2 on it and run all your kids' games natively.
    4 or 5 iPods
  5. #24
    jakebrake3202's Avatar
    Join Date
    Mar 2008
    Location
    Nebraska
    Posts
    I have one set up in my living room. I have it plugged into my audio system and use it as a jukebox with different playlists for parties and such. Everyone is always intrigued by the visuals in itunes when I have them on.
    I have turned several others into iMacquariums.
  6. #25
    geordisjd's Avatar
    Join Date
    Jul 2007
    Posts
    2,725
    42
    Quote Originally Posted by jakebrake3202 View Post
    I love them! However, I'm not ready to sacrify any of my working Macs to turn them into a fish tank. I don't own any non-working Mac. Actually, I've never even met one!
    4 or 5 iPods
  7. #26
    billnye97's Avatar
    Join Date
    Jun 2007
    Location
    Cleveland
    Posts
    185
    9
    Very cool and trendy. After I buy my Macbook I'm gonna look into getting one. My cats would go crazy.
  8. #27
    Join Date
    Mar 2008
    Location
    Nebraska
    Posts
    Quote Originally Posted by billnye97 View Post
    They are cat proof. My cat sits on top of my iMacquarium and stares through the case at the fish swimming inside. The only thing she can do is paw at plastic. She walked around it for hours when I got it set up, just trying to figure out how to get at the fish inside.
  9. #28
    iHero's Avatar
    Join Date
    Aug 2008
    Location
    Washington State
    Posts
    105
    You should give one of those G3's to me. I've upgraded my iMac G3 350MHz from OS 9 to OS X. You need to upgrade the firmware, and upgrade to at least OS 9.1. If you have any questions, feel free to PM me and I'll give you my GTalk or MSN address.
    I'd upgrade to 10.4 but I need more RAM.
    Jailbroken 8GB iPod Touch - 4GB Third Generation Nano - 2GB First Generation Nano - 1GB Second Generation Shuffle
  10. #29
    geordisjd's Avatar
    Join Date
    Jul 2007
    Posts
    2,725
    42
    I'm running 10.4.11 on my G3 iMac:
    It's also still able to run classic. I'm maxed out on the RAM, which makes a big difference. It's a very nice and smooth little machine.
    4 or 5 iPods
  11. #30
    iHero's Avatar
    Join Date
    Aug 2008
    Location
    Washington State
    Posts
    105
    Isn't 1GB the max, or do you have the model with only that much as the max amount of ram?
+ Reply to Thread
Page 3 of 3
FirstFirst 1 2 3
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
