Someone w/ Mac please help! quick!
This is a discussion on Someone w/ Mac please help! quick! within the iMac forums, part of the Apple Hardware and Software category; couple things: Best Buy should be the ones to restore the item to its factory condition before they give it ...
+ Reply to Thread
Page 3 of 4
FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 32
Thread: Someone w/ Mac please help! quick!
  1. #21
    acosmichippo's Avatar
    Join Date
    Sep 2007
    Location
    Location Location
    Posts
    9,628
    112
    couple things:
    Best Buy should be the ones to restore the item to its factory condition before they give it to you. I work there, and find it extremely unacceptable that they gave you a floor model in that condition.
    But if you DID run the SL install disc, it sounds like you didn't check the "erase and install" option, so you upgraded the OS while leaving on all of the software and restrictions the apple demo adds on.
    In short, if you don't want to deal with it, take it back to best buy (Geek Squad, specifically) and insist they restore your computer.
    Go ahead, quote me. I dare you.
  2. Click here to register for our iPhone forums and remove these ads.
  3. #22
    Mickeylittle's Avatar
    Join Date
    Feb 2009
    Posts
    1,652
    99
    No doubt take it to them cause even if you reinstall and check the 'erase and install' button, you still don't have the applications disc so all you would have is the operating system.
  4. #23
    Cjvdh's Avatar
    Join Date
    Mar 2009
    Location
    York, PA
    Posts
    1,286
    22
    Blog Entries
    styfle that did not work man because it asked me for a password and i do not know it and either does bestbuy. WTF!!!@!@!
    C E E J A Y PRODUCTIONS
    iPhone 3G[S] // 21.5 iMac // iPad [coming soon!]
  5. #24
    styfle's Avatar
    Join Date
    Mar 2008
    Posts
    2,843
    114
    Well just use linux to wipe the drive lol. Burn an image of ubuntu to a disk and boot off of that.
    2.5Ghz Custom PC (XP) + 2.0GHz Aluminum MacBook
    I made a java game, tell me what you think.
  6. #25
    Cjvdh's Avatar
    Join Date
    Mar 2009
    Location
    York, PA
    Posts
    1,286
    22
    Blog Entries
    Quote Originally Posted by acosmichippo View Post
    couple things:
    Yeah well I went in the store at 8:00 and they close at 9:00 and none of them had time they said. Trust me I am going to bed now but when I wake tommorrow all helllll is breaking lose I am calling them and apple I will have this **** fixed tm
  7. #26
    Join Date
    Sep 2007
    Location
    Location Location
    Posts
    9,628
    112
    if you boot to the SL disc, you should not need a password to format the drive using Disk Utility.
  8. #27
    Join Date
    Sep 2007
    Location
    Location Location
    Posts
    9,628
    112
    Quote Originally Posted by Cjvdh View Post
    well, that's a different story. If you had to take it home tonight (i don't blame you for feeling that way), that was your call.
  9. #28
    Cjvdh's Avatar
    Join Date
    Mar 2009
    Location
    York, PA
    Posts
    1,286
    22
    Blog Entries
    I called apple and they fixed it for me. Thanks for all of the support guys I am now up and running on 10.6 snow leopard.
  10. #29
    Join Date
    Feb 2009
    Posts
    1,652
    99
    Curiosity killed the cat so meow! How did they fix it for you?
  11. #30
    Cjvdh's Avatar
    Join Date
    Mar 2009
    Location
    York, PA
    Posts
    1,286
    22
    Blog Entries
    Quote Originally Posted by Mickeylittle View Post
    I had erase previous "demo" software and re install the snow leopard and it worked fine. It asked me for all my information as if I was setting up a brand new computer and I did all of that and its working perfect!
+ Reply to Thread
Page 3 of 4
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
