Go Back   iPhone Forums > Apple Hardware and Software > iMac
Old 06-23-2008, 01:48 PM   #1 (permalink)
Hondamaker's Avatar
Default OS Leopard question
my iMac is running Leopard, and one of the multitude of features is the keyboard viewer. I was messing with it, and now it appears each time I log on. I've tried everything I know (I'm still learning) to get it to stop loading, but I can't. Can someone help?
"Oh Father of the Four Winds, fill my sails, across the sea of years.With no provision, but an open face, along the straits of fear..."
Hondamaker is offline
Old 06-23-2008, 03:42 PM   #2 (permalink)
dturner's Avatar
I have a laptop, but maybe this will help. Sure hope so.
Choose Apple menu > System Preferences and click International.
Click Input Menu, then select the checkbox next to Keyboard Viewer.
Select the On checkbox next to the language whose keyboard layout you want to use.
Choose Show Keyboard Viewer from the Input menu (international symbol) on the right side of the menu bar.
Don
Follow me on Twitter
Come Chat With Us In The EIC Chatroom
dturner is offline
Old 06-23-2008, 03:56 PM   #3 (permalink)
dturner's Avatar
Above may be of no help. Go here and watch. Easier than trying to explain.
Don
dturner is offline
Old 06-24-2008, 02:02 AM   #4 (permalink)
Hondamaker's Avatar
That's the video I watched to show me how to use keyboard viewer, but now I want to turn it off but can't. I unchecked the boxes to no avail!
Old 06-24-2008, 09:57 AM   #5 (permalink)
Super Moderator
Lincoln's Avatar
Try this:
Open System Preferences and open the Accounts pane, and authenticate if necessary. (You'll need to if the lock in the bottom corner is closed.) Select your account, and go into the Login Items pane. In the list you now see, look for something similar to "Keyboard Viewer". Highlight it, and click the - button below.
- John
Lincoln is offline
Old 06-24-2008, 12:09 PM   #6 (permalink)
Hondamaker's Avatar
Originally Posted by John View Post
Try this:
- John
Believe this or not, it's not on the list! But when I log on, there it is, buggin the **** outta me!
Old 06-24-2008, 03:08 PM   #7 (permalink)
dturner's Avatar
Try this. Go to Sys. Preferences. Click on International-Input Menu. The second line down is keyboard viewer. Can you uncheck that? This should fix it.
Don
dturner is offline
Old 06-24-2008, 03:30 PM   #8 (permalink)
Hondamaker's Avatar
Yeah, it's unchecked. I thought that would do it, but it didn't.
Old 06-24-2008, 03:39 PM   #9 (permalink)
Hondamaker's Avatar
OK, I had to reboot the iMac. That did the trick. Rebooting to get rid of a start-up item is so Windows-like!
Old 06-24-2008, 03:43 PM   #10 (permalink)
dturner's Avatar
Glad you got it fixed. Crap like that drives me crazy too so I know what you mean.
Don
dturner is offline
