Everything iPhone iPhone Accessory Store iPhone news iPhone accessory reviews iPhone forums
Go Back   iPhone 3G | iPod touch Forums > Apple Hardware > iMac
Notices
iPhone versions available: Enhanced | Light
iPhone Social
Thread Tools Display Modes
Old 04-19-2008, 10:35 AM   #1 (permalink)
Default Need iMac Advice please
I am a longtime Windows user and the only Apple product I have is my iPhone. My desktop crashed and I have been considering getting an iMac. The stability of Mac systems versus the buggy Microsoft is appealing to me but I just want some advice before I make a purchase. What is the main difference I will notice switching to a Mac? Will I be dissapointed? Is there many compatability issues? I guess I should mention that I will only be using this system mainly for internet browsing use.
I would really appreciate any advice, thanks!
itsabouttime is offline   Reply With Quote
Old 04-19-2008, 11:05 PM   #2 (permalink)
acosmichippo's Avatar
wow, that's a lot of very broad questions... so i guess i'll give you my perspective. I made the switch in early February, and i have no regrets (i have a macbook pro). The biggest difference i noticed was how applications install into OSX (which is mindbogglingly easier than in Windows). There are definitely compatibility issues. A lot of things developed for Windows will just not work on a Mac, but the good news is there is usually (if not always) a Mac counterpart that works just as well (if not better). And then, even if you NEED a specific piece of software that only runs on windows, you do have the option to use Bootcamp, Parallels, or Fusion to run Windows on your Mac.
Considering what you're going to use it for, i don't think you will see hardly any negatives to the switch.
[/sarcasm]
acosmichippo is online now   Reply With Quote
Old 04-19-2008, 11:28 PM   #3 (permalink)
Thanks a bunch, I really appreciate your advice. I'm really looking forward to making the switch.
Old 04-20-2008, 06:54 AM   #4 (permalink)
jpetticrew's Avatar
Send a message via AIM to jpetticrew
Yea, dude! Go for it!I made the switch in October of last year with a Mac Mini, and I have never looked back. Like the hippo (I'm not calling HIM a hippo ) said, any software you have that doesn't run on a Mac can usually be replaced by a freeware piece of software.
You absolutely will not regret it.
2.4 ghz MacBook Pro with 4 Gb RAM and a glossy screen
4gb iPhone on firmware 2.0
Last edited by jpetticrew; 04-20-2008 at 05:35 PM. Reason: Wanna make sure acosmichippo is not offended.
jpetticrew is offline   Reply With Quote
Old 04-20-2008, 06:57 AM   #5 (permalink)
i'm a guy. avatar is a bit misleading, i guess.
sorry to get your hopes up.
[/sarcasm]
Old 04-20-2008, 05:37 PM   #6 (permalink)
jpetticrew's Avatar
Haha, nah, I'm sorry. I'm still pretty new, I don't know who everbody is and stuff yet.
Old 04-20-2008, 08:55 PM   #7 (permalink)
Napoleon_PhoneApart's Avatar
You look like the oldest daughter (Erin?) on "The Waltons."
Oh, Mother of God, please, please thank me or I'll have to double up on my Zoloft to keep my fragile self-esteem going.
(waah. waah, waah...)
Napoleon_PhoneApart is online now   Reply With Quote
Old 04-20-2008, 08:58 PM   #8 (permalink)
Lincoln's Avatar
Send a message via AIM to Lincoln
No compatibility issues, much better interface, much for stable, Apple has better customer support, works seamlessly with iPhones, iPods, etc., and if you ever feel the urge to use Windows ( you won't. ) then there's always Boot Camp. Apple's Get a Mac page may also be helpful to you.
The only downside is that when you buy the Mac, you will hurt yourself for using PCs for such a long time.
- John
Lincoln is online now   Reply With Quote
Old 04-20-2008, 09:42 PM   #9 (permalink)
Quote:
it's not me.
i should probably change it...
[/sarcasm]
Old 04-20-2008, 09:57 PM   #10 (permalink)
there we go. that should avoid any confusion.
[/sarcasm]
Bookmarks
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Integrated by BBpixel ©2004-2008, jvbPlugin
Android forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
