Go Back   iPhone Forums > Apple Hardware and Software > iMac
Old 09-17-2008, 06:56 AM   #1 (permalink)
Exclamation Help, imac flashing ? At startup
can somone help me, i update my imac with the new update, everything was fine, then i turn off my computer for the night,and the next day i try to turn it on, and all i get is a flashing ? if anyone here know how to fix this problem please help me, i try to put the install dvd in and do a repair with no luck.help, help,help
the watcher is offline
Old 09-22-2008, 11:56 AM   #2 (permalink)
fury's Avatar
How new is it? If it's still under the original 1-year warranty, you might be best off getting it looked at at an Apple store.
back in white baby! 32 gig that is!
fury is offline
Old 09-22-2008, 12:26 PM   #3 (permalink)
Swagger's Avatar
Try pressing and holing the power button until you hear a beeping sound. Doing that causes a reset, it should help your problem. You might just need a fresh mount of the software.. Mark
Constantly having to be tethered to a charger is NOT MOBILE in my opinion (I.e., iPhone 3GS battery).
Swagger is offline
Old 09-23-2008, 09:18 PM   #4 (permalink)
Hey guys, thanks for the help, but i tried everything and i could not get it, and i did not have anything backed up so i had to make a very hard decision, plus my warranty is up. so i had to erase everything and start over,That SUCK but at least now my mac is running like it should and yes i bought an external hard drive
