Go Back   iPhone Forums > Apple Hardware and Software > iMac
Old 01-07-2009, 05:01 PM   #1 (permalink)
Default Good Burning Program & Question About Caps Lock
Does anyone know a good burning program which burns music to CD's and movies to DVD's such as ConvertXToDVD for Windows?
And does anyone else have the problem when typing with the iMac with the CAPS lock button. If your typing something and you want the CAPS lock on, it doesn't always come on, then when you go back to see what you have typed, you realize the bits in CAPS are characters which shouldn't be, then you have to go back and do it all again
Danaldinho is offline
Old 01-07-2009, 05:09 PM   #2 (permalink)
Hondamaker's Avatar
I use WMP to copy music to cd and I use DVDDecrypter, or DVDShrink, along with AnyDVD from Slysoft.
As for your capslock problem, I have an iMac, and I haven't seen that one. Maybe it's your keyboard.
"Oh Father of the Four Winds, fill my sails, across the sea of years.With no provision, but an open face, along the straits of fear..."
Hondamaker is offline
Old 01-09-2009, 11:21 AM   #3 (permalink)
Must be then
Also what is WMP, is that Windows Media Player?
Old 01-09-2009, 12:29 PM   #4 (permalink)
Hondamaker's Avatar
Must be then
Yep, windows media player.
Old 01-09-2009, 12:34 PM   #5 (permalink)
Well can you use that on an iMac?
Old 01-09-2009, 03:07 PM   #6 (permalink)
Hondamaker's Avatar
****, I forgot you're on an iMac. You know, I've never made a music cd on my mac, so I dunno! Sorry dude.
Old 01-09-2009, 03:19 PM   #7 (permalink)
LMAO, Its cool mate
What about the burning DVD programs you mentioned, have you used them on a iMac?
Old 01-09-2009, 03:29 PM   #8 (permalink)
Hondamaker's Avatar
LMAO, Its cool mate
I use them with windows on my mac, using Bootcamp.
Old 01-09-2009, 07:15 PM   #9 (permalink)
Ramesh's Avatar
Try Toast. I have it, and I like it. Plus - you could always use the built in burning features of OS X - but I like the interface of Toast.
Follow me on Twitter
Ramesh is online now
Old 01-11-2009, 03:20 PM   #10 (permalink)
acosmichippo's Avatar
iTunes will burn audio CDs, and iDVD will burn DVDs. For anything else, there's disk utility.
What are you specifically trying to do?
acosmichippo is online now
